[ANSYS Meshing] Inflation on different axis are cancelling themselves out, how can i fix? |
April 14, 2017, 20:48 |
Chris
Hello, I'm currently working on a project to model the flow of air across an airfoil. When attempting to add inflation to the blade for the boundary layer, or the inflation along the close and endwall of the domain, each work fine individually, however when I combine them, one cancels the other out and i only end up with one. I was wondering if there was a way I could resolve this within the ansys meshing tool, without having to use something like ICEM?
Please find attached the photos displaying the model. Chris |
April 19, 2017, 09:11 |
Paritosh Vasava
Rep Power: 23 |
You have a perfectly sweepable domain. So, why dont you use sweep with bias on the whole model and then introduce inflation on the blade wall.
meshing 3d, meshing advice, meshing basics |
[DesignModeler] axis display disparity of model and triad | ram881973 | ANSYS Meshing & Geometry | 14 | November 18, 2020 02:21 |
[ANSYS Meshing] Inflation Layers Being Finicky | Markua | ANSYS Meshing & Geometry | 12 | April 28, 2015 08:11 |
[Other] dynamic Mesh with angular velocity not parallel to x axis | donQi | OpenFOAM Meshing & Mesh Conversion | 5 | October 3, 2014 00:19 |
Axis treatment in axisymmetrical problem | Jakob1 | OpenFOAM Pre-Processing | 2 | August 25, 2014 04:09 |
Fluent diverges when using inflation layers | ziggo | FLUENT | 4 | August 9, 2013 13:11 |
