[ANSYS Meshing] Error: Conflicting Zone Names |
April 12, 2017, 23:35 |
Sakeen
Rep Power: 9 |
I have renamed all my geometry, contact regions and named selections. However I get an error message that says "The mesh translation to Fluent failed due to conflicting zone names." I have attached an image to show the geometry names and the error message. Does my named selections and contact regions need to be the same name? would a different name of a contact region and a named selection cause a conflict? Would anyone be able to help resolve this problem? Thanks, Sakeen. |
April 19, 2017, 08:16 |
Paritosh Vasava
Rep Power: 23 |
I assume you have figured this out already. But if not, you must have included same boundary in multiple name selection. You can also fix it with Repair Overlapping Name Selection (it is visible when you right-click on the Named Selections).
April 20, 2017, 03:11 |
Sakeen
Rep Power: 9 |
Thank you for your reply, and yes I have figured it out. But if you may please help me with another issue I am having , I need to modify my geometry to separate solid zones and fluid zones and I am not sure how to do it. I know it has to be done during meshing, but I do not know how
April 20, 2017, 05:47 |
Paritosh Vasava
Rep Power: 23 |
You should be able to split your geometry using boolean operations in the CAD program i.e. Design Modeler or SpaceClaim. You can watch following videos to get hints/instructions.
If you are using Design Modeler, you can follow this video and if If you are using Spaceclaim, you can follow this video. |
April 20, 2017, 06:58 |
Sakeen
Rep Power: 9 |
thanks a lot vasava, your help is very much appreciated. I shall have a look.
error, meshing, zone |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
