[ANSYS Meshing] Micro Composite Patch on Carbon Fibre Reinforced Ploymer
Old   April 10, 2017, 10:58
Default Micro Composite Patch on Carbon Fibre Reinforced Ploymer
Nidish Narayanan
NidishNarayanan is on a distinguished road
I want to design a geometry and subsequently use it to do a couple field analysis, static structural and transient analysis.
I have a Micro Composite Patch(85*28*0.3 mm) that has a piezoelectric property which is glued on top of a Carbon Fibre Reinforced polymer beam(400*45*1 mm).
I developed the model in MAPDL and tried to sweep mesh the two volumes.But one volume(CFRP) would not mesh.
Please provide suggestions.
NidishNarayanan is offline   Reply With Quote
Old   April 19, 2017, 09:19
Paritosh Vasava
vasava will become famous soon enough
Were you able to solve your problem with Ansys meshing?
vasava is offline   Reply With Quote
Old   April 19, 2017, 09:58
Nidish Narayanan
yes, I managed to solve it. But I still am looking into the problem of how to model a piezoelectric patch on a composite material . I have seen different videos on youtube, tutorials and all but not really helping.
composite, composite fibrte, coupled field., microfibre patch, piezoelectric
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
