[ANSYS Meshing] Changes to Model after Grid Independent Study
Old   April 8, 2017, 17:31
Default Changes to Model after Grid Independent Study
Daniel
bees1995 is on a distinguished road
Hi guys,
I was wondering whether it is possible to make small changes to the model once grid indpendence has been achieved? Specifically in my case I'm looking to model flow around an aircraft empennage and I wanted to determine the effects of rudder and elevator input. Rather than doing a grid indpendent study for each case I was hoping to save time and do it for all in one go.
Thanks for your help!
bees1995 is offline   Reply With Quote
Old   April 8, 2017, 19:27
Lukas Lebovitz
lukas.lebo is on a distinguished road
I don't really have much experience with this, but I'm sure other people can only help you when you get a bit more specific. Like are you considering compressible or incompressible flows? What turbulence model are you using?
When you found a "best practice" for mesh-refinement for one case, you can expect that it will at least behave very close for similar cases. You can always confirm this by doing one more simulation of the same case with a more refined or coarser mesh (±20% computational cost is already enough to tell). If your case runs under extreme conditions and at the edge of grid independency, I'd recommend to validate it for at least one case-variation.
People usually rely on said "best-practice" because you can't really do a mesh study for every commercial project (when they are all similar).
Cheers,
Lukas
lukas.lebo is offline   Reply With Quote
Old   April 8, 2017, 20:01
Daniel
Hi Lukas,
I'm doing an incompressible simulation and using an SST turbulence model.
Old   April 8, 2017, 20:05
Daniel
But the cases I am running are fairly "safe" in their setup, running at low-speed, incompressible flow over structures that are aerodynamically smooth i.e. no overly turbulent flow, so I would expect some resilience in the mesh. I was just wondering if it's common practice to do so. I'm not looking for super accurate results, so slight errors that occur when the model is altered and the resulting mesh not being independent is fine for me.
Old   April 8, 2017, 20:22
Lukas Lebovitz
Incompressible RANS (especially SST) simulations have rather stable grid-behaviour when it comes to variations in geometry. You should be good.
3d flow, grid indpendent study, meshing
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Problems with convergence and grid independence study nikn CFX 0 August 26, 2015 07:32
grid study, important question hamid1 FLUENT 1 August 4, 2013 01:14
Grid resolution in porous medium model for heat sink Chander Main CFD Forum 4 April 2, 2012 11:56
Grid Refinement Study - How many cells necessary for accurate results? ejvikings FLUENT 1 January 22, 2012 01:33
