[TGrid] Problem when generating volume mesh "tg-is-point-in-region" |
April 3, 2017, 08:32 |
Rep Power: 10 |
Hi all, I'm a university student new in these forums. I am involved in Formula SAE aerodynamics and I am required to run simulations related to the car.
I managed to get a surface mesh of minimum skewness 0.7 and ran a diagnostics of non-manifold, invalid normals and close proximity test and have manually fixed the surfaces. However, when generating volume mesh, I ran into a problem. The mesher managed to initialise mesh and generate regions, but afterwards, it showed "Error: %tg-is-point-in-region: wta[1](zone)" and the compute process crashed. I have no idea what this error message means and did not manage to find any results through search engines. I hope to learn from this forum. Thank you! |
April 16, 2017, 13:19 |
Rep Power: 10 |
Hi all, I'm still running into this problem even though I've already changed my surface mesh. What can be the possible reasons that can trigger this error code?
The error code is seen in the attachment. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 07:51 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 01:37 |
[blockMesh] Problem with Mesh Volume | seboxx | OpenFOAM Meshing & Mesh Conversion | 3 | January 30, 2012 09:19 |
