March 30, 2017, 22:50 |
Domain inside a structure
Sakeen
Rep Power: 9 |
I am trying to define a domain inside a machine casing that I have drawn using ProE. The machine has components on the inside and I am trying to create a fluid domain for the inside of the machine casing so that i can mesh it from the inside. I have attached a image of the geometry. I have few experience with ANSYS, and it would be very much appreciated if someone would help. Kind regards, Sakeen. |
April 4, 2017, 15:48 |
Erik
Rep Power: 23 |
Try "enclosure" in design modeler.
Or fill the box with a solid (add frozen) and then use "boolean" to subtract the components. |
April 4, 2017, 19:20 |
Sakeen
Rep Power: 9 |
design modeller, domains, geometry ansys, meshing 3d |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Generating Velocity Profile inside domain. | Hisham | OpenFOAM | 0 | June 7, 2011 07:25 |
Constant flow rate through a small area inside the fluid domain. | robingilbert | OpenFOAM | 7 | October 4, 2010 16:19 |
Heat source in a particular region inside the fluid domain | robingilbert | OpenFOAM | 7 | September 2, 2010 14:39 |
