Prince Hossain
Rep Power: 9 ![]() |
i want generate mesh on tube which internal diameter is.8 mm. so the fluid volume diameter is .8 mm. i tried to generate mesh but it failed. how can i mesh in such small model.
Patcharawat
Rep Power: 12 ![]() |
You can use other programs such as GAMBIT and ICEM for meshing and later import the generated mesh into fluent.
Sent from my iPhone using CFD Online Forum mobile app |
cfd analysis, mesh 3d, thin channel |
Model assemble - meshing strategy | Aeronautics El. K. | Pointwise & Gridgen | 7 | August 8, 2015 03:30 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! | lau06165 | ANSYS Meshing & Geometry | 1 | March 22, 2010 01:09 |
thin extrusion meshing | guillaume | Main CFD Forum | 0 | October 27, 2008 18:36 |
Meshing thin surfaces | Louwrens | CFX | 8 | August 18, 2003 17:49 |
