Two concentric cylinders
Old   March 18, 2017, 13:29
Post Two concentric cylinders
Plaschko
Plaschko is on a distinguished road
For fluent experts: Steady flow over a cylinder
Hello everybody, I am new in Fluent flow. I used a geometry with two concentric cylinders D1=5m, D2=64m. I do not know what means frozen and needed extruded cylinders to activate the Boolean subtraction. "Surface from Sketches" : did not work.
I used the circles with identical depth (20 m) and I tried to apply the ittle cyl. (the solid cylinder with add material, Tool Body) and used the outer one (to simulate the flow field as frozen, Target Body), The Boolean subtraction was active but the face selection filters did not work (not active).
Thank you for help , Peter
Plaschko is offline   Reply With Quote
[ANSYS Meshing] Mesh of concentric cylinders with hole DDL ANSYS Meshing & Geometry 5 May 25, 2016 11:00
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 11:02
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 10:22
concentric rotating cylinders with st-st flow having and mass transfer hossein.mashhadi Main CFD Forum 0 April 10, 2011 07:03
Flow Between Concentric Cylinders larscliff ANSYS 0 February 17, 2011 05:43
