[ICEM] Issue to create conformal interface between stationary and rotating domain |
March 17, 2017, 07:27 |
Rep Power: 10 |
Hi Everyone,
I am struggling to get conformal interface between rotating and stationary domain for the Vertical Axis Wind Turbine. I have same number of nodes and node distribution still I am hitting with the problem. What would be the probable solution to avoid it. I am using hexa mesh in both the regions. Thanks in advance!!!!!! |
March 17, 2017, 09:27 |
#2 | |
Kushal Puri
Rep Power: 12 |
March 17, 2017, 12:35 |
Rep Power: 10 |
I have created two separate project files for both the domains and imported it to the solver. I did not merge it please correct me if I am missing anything.
March 17, 2017, 13:28 |
#4 | |
Kushal Puri
Rep Power: 12 |
Go to mesh-> fuse then select the two parts which you want to merge and give very small tolerance. |
March 17, 2017, 13:39 |
Rep Power: 10 |
I have sliding interface between stationary and rotating domain. I do not know about fusing but I will try what you said.
March 20, 2017, 10:05 |
Rep Power: 10 |
Hi Kushal,
I have tried what you said but I don't want to fuse the mesh because after fusing, the mesh corresponding to rotating region will not rotate. |
March 20, 2017, 10:19 |
Kushal Puri
Rep Power: 12 |
March 20, 2017, 15:24 |
Rep Power: 10 |
I have a rotating domain in light green colour and the stationary domain in green colour. I want exact overlapping of nodes at marked positions.
March 21, 2017, 14:11 |
#9 |
Kushal Puri
Rep Power: 12 |
But why you need exact overlapping nodes when you are working with rotomachinery. If you are not not merging the nodes then there is no point of having same nodes on both the interface
March 22, 2017, 17:44 |
#10 |
Rep Power: 10 |
Thanks a lot for your help Kushal. I have solved my problem by creating both the domains in a single project file.
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
horizontal axis wind turbine- Issue in interface b/w stationary and rotating domain. | srijithbbk | CFX | 5 | February 22, 2016 04:20 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
