[DesignModeler] Cannot modify lines and surfaces in Ansys DesignModeler
Old   March 17, 2017, 00:32
Default Cannot modify lines and surfaces in Ansys DesignModeler
Ian Carlo M. Lositaņo
iancmlositano is on a distinguished road
I created lines and surfaces in DesignModeler using an imported set of points from a .txt file, which defines an airfoil. These lines and surfaces, though, remain in the sketch they were created in and could not be transfered and edited like copy or duplicate. Is there a procedure I am missing from that which I do:
1. Create a new sketch;
2. Generate;
3. Go to /Sketching tab;
4. Select geometry to edit; and
5. Edit geometry by going to /Modify tools in the tab and clicking on the appropriate tool?
Step 4 could not be done in my case so no edit takes place.
I am new to Ansys although I have experience in CAD, particularly AutoCAD.
Thanks!
Sent from my HUAWEI TIT-U02 using CFD Online Forum mobile app
iancmlositano is offline   Reply With Quote
[Workbench] Beginnerquestion: 2D lines in SOLIDWORKS importing to ANSYS component system cfdnoob ANSYS Meshing & Geometry 0 August 12, 2014 13:45
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 04:54
