[ANSYS Meshing] Airfoil edge sizing mesh generation problem
Old   March 6, 2017, 14:50
Default Airfoil edge sizing mesh generation problem
Kostas_K is on a distinguished road
Hello everyone,
I am trying to create a mesh so i can solve the case "flow around an airfoil" using Ansys. I already created the geometry and divided it in 6 faces. Then for the mesh i used edge sizing (see Mesh_sizing.png).
All the edges going towards the airfoil have :
Number of divisions = 50
Behavior = Hard
Bias type = (depends the line)
Bias option = Bias Factor
Bias Factor = 150
The rest faces are divided the same way but with no bias.
I also use Mapped Face Meshing with Method = quadrilaterals
However when generating the mesh it is like the edge sizing is not being considered as a parameter. The result i get when i generate the mesh is (see Wrong_mesh.png). The boundary of the mesh as seen (see Zoom.png) is divided how i want but the lines are not connected with the dots. What i would expect is something like this (right_mesh.png).
Does anyone know how to fix this ?
Thank you in advance
Kostas_K is offline   Reply With Quote
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? Pol.P FLUENT 9 March 7, 2022 18:21
Mesh generation for 3d airfoil woth serrations chhabraabhinav95 Main CFD Forum 1 February 20, 2017 18:55
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Airfoil simulation solution interfered by mesh Dvergr OpenFOAM Running, Solving & CFD 1 September 28, 2014 03:05
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
