[ICEM] How to make parallel node distribution between two cylindrical curves |
March 3, 2017, 04:41 |
Prikane
Rep Power: 10 |
Dear colleagues,
I am currently trying to create 2D structured quad mesh between 2 surfaces (upper - cylindrical surface and bottom - flat surface) as you can see on the picture 1 given in attachment. Minimum gap between these two surfaces is 0.0001 mm. Highly structured mesh with quad elements is desirable type of the mesh because I am planing to apply dynamic mesh on the cylindrical surface. This type of the mesh is also recommended in the literature on which I am relying for this project. For my project, I need to get mesh as it is shown on picture 3 given in attachment, with perpendicular vertical mesh. I tried to use O grid but without success. In my opinion, I can not use O grid and the problem must be with matching the bunching between two sets of edges. Dear colleagues if anyone have some suggestions I would be very grateful. Best regards, Prikane Last edited by Prikane; March 3, 2017 at 06:09. |
March 6, 2017, 03:27 |
Prikane
Rep Power: 10 |
Does anyone can help me?
March 6, 2017, 05:42 |
Kirill Makarov
Rep Power: 9 |
Dear Prikane!
First of all try to change mesh law on bottom edge. There are dozen of variants and I honestly can't say which one you should choose but my best guess is between Poisson and ReferenceMesh. |
March 6, 2017, 09:21 |
Prikane
Rep Power: 10 |
Dear Kirill_Makarov,
Thank you for your help. I tried many different meshing laws but I can not find the right one. I tried also your suggestion - Poisson distribution but without any success. Can you give me some advice how to use ReferenceMesh? Thanks in advance, Prikane |
cylindrical surfaces, ehl, mesh, parallel nodes, perpendicular vertical |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
all processes end up in the same node when submitting parallel job by SGE | man@hepia | OpenFOAM Running, Solving & CFD | 5 | November 16, 2012 09:42 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 03:36 |
how to make particle size distribution | adma | CFX | 0 | January 10, 2006 16:57 |
