[ANSYS Meshing] Meshing Error
Old   February 25, 2017, 16:28
Post Meshing Error
Malik
UsmanSikandar is on a distinguished road
(1)The following entities failed to mesh. The meshes of the bodies containing these entities are not up-to-date. However, meshing may be successful on the other entities.Project>Model>Geometry>shell Bodies>shell
(2)The following surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology.Project>Model>Geometry>shell Bodies>shell
(3)A mesh could not be generated using the current meshing options and settings. Hint: The problem geometry areas might have been highlighted. Switching to wireframe mode may make them more visible.Project>Model>Mesh
Coil is meshed while shell is not meshed ? Ways to solve the problem?
UsmanSikandar is offline   Reply With Quote
ansys
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
