February 18, 2017, 18:51 |
Need help - mesh cell count.
Syed
Rep Power: 9 |
Hello everyone, I am currently using student version of ANSYS 16.0. I want to perform a 3d simulation of a helicopter airframe (without rotor) which is kept inside a rectangular domain (enclosure).
The mesh of the model got generated successfully but I am not able to export it to Fluent. It says the error "This is an educational executable, and can only be used with cases containing less than 512,000 cells." My model's nodes are 871,000. Is there a way to reduce cell count without removing any parts from the geometry? I have kept mesh as coarse.. Please help ! |
February 21, 2017, 07:24 |
Paritosh Vasava
Rep Power: 23 |
In the 'Details of "Mesh"' part, try changing values for 'Min Size', 'Max Face Size', 'Max Tet size' etc. You can notice how the mesh size is changing and figure out appropriate values for your case.
cell count, mesh 3d |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
