[ICEM] Boundary Layer Y+ Mesh Not Working as Expected |
Abhimanyu
Rep Power: 12 ![]() |
Hey,
I am using ICEM to generate quadrilateral and hexahedral grids for Airfoils and Wings. The flow Re number is 3 million. The corresponding first cell center height for a grid with y+ <1 is 8.5e-6m. Now earlier I have generated grids without any problem but for the recent work that I am doing I am not getting the grid spacing as I wish. A considerable number of cells from the airfoil wall have a constant thickness even though I have specified the grid growth ratio as 1.2. And the corresponding first cell height is less than required. I have attached pictures which will help explain the problem. Any help is appreciated. It is causing problems when I solve for the flow. Thanks https://drive.google.com/open?id=0B4...TdOMTZjdV8yalU https://drive.google.com/open?id=0B4...k5STUtILTRYakk https://drive.google.com/open?id=0B4...TdOMTZjdV8yalU |
William
Rep Power: 10 ![]() |
I'm also simulating airfoils but I'm fairly new. According to what I've read in Fluent Theory guide it is recommended that you apply meshes with Y+ < 1 and expansion factors smaller than 1.1 - but you should keep it above 1.05. Before I read that I always used growth ratio of 1.2.
I can't view your figures. You can attach them to the post. Also upload a screenshot of your edge bunching settings. |
Abhimanyu
Hey,
I have attached the pics now. Kindly have a look and let me know if you can figure something out. I have tried various growth ratios and none seem to work. The edge spacing markers seems alright but the grid being formed does not match the markers. |
#4 | |
William
Spacing 1 = 0 |
Abhimanyu
Tried that as well. Didn't work.
If I reduce the spacing 2 to 8.5e-4, it works fine but then my first cell wouldn't be in y+<1 range. |
Pierre-Luc
Rep Power: 14 ![]() |
I have exactly the same problem as you (Edge nodes distribution not properly used with ICEM v17.1 ). What version of ICEM are you using? I only encountered this issue with v17.1, I have no problem with v16.2. A blocking that was working with v16.2 does not work the same way with v17.1 and shows the error you get. So my guess is that it could be kind of a bug of v17.1... So far I have not found how to fix that and this is quite annoying... Now that this is not only me, maybe we should contact ANSYS directly. |
William
I'm not sure if it's a similar problem I had once. My triangular mesh didn't generate when I had really small wall spacing. I had it fixed by increasing the number of processors ICEM could use. I think by default it is 1 processor. Settings -> General -> Number of Processors. I think if you set value of 0... It will use the maximum number of available processors. You can also fix the number as 2, 4 or as many processors you have. Give it a try! |
Abhimanyu
I am using v17.1. I will have to try this with some other version as well to check if that is the issue. Any idea how to go about getting this to ansys?
#9 |
Abhimanyu
I changed the processors to 4. Didn't solve the problem.
#10 |
Pierre-Luc
Hi Abhimanyu,
I have just sent an email to ANSYS support. I will let you know when they reply. |
#11 |
Pierre-Luc
I just got a reply. Actually we just need to modify the Triangulation Tolerance (Settings > Model/Units). Set it to 1e-7 and everything should be fine. You may need to adjust the value but it works in my case. The default value was probably different in the previous versions... Regards, |
#12 |
Abhimanyu
Yeah...It worked. But I opened the project file in ICEM v14 and there it had no issues with the default tolerance settings. And they were the same as v17 i.e. default of 0.001. Weird behavior.
But atleast we got the solution. Thanks for reaching out to ansys and getting it done. |
airfoil, boundary cells, icem 17, wing simulation, y plus ranges |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
