[ICEM] Question regarding ICEM meshing of combustion chamber wall as well as fuid domain
Old   January 24, 2017, 17:06
Default Question regarding ICEM meshing of combustion chamber wall as well as fuid domain
Manish Das
manny9808 is on a distinguished road
HI,
I've been trying to perform meshing of a combustion chamber in ICEM for final year project.The idea is to capture both wall thickness as well as fluid domain inside.Here is the step that I underwent:
1. Created a CATIA model
2. Imported to ICEM, created block, split block for wall thickness and fluid domain region.
3. Associated the block accordingly and created grid.
But the problem is that in order to capture fluid domain as well, I have to create solid element for the fluid region as well like concentric cylinders where outer solid one is the wall and the inner solid one is the fluid.
This approach fails when the complexity of the combustion chamber's geometry increases.
Is it possible to capture the wall thickness as fluid domain together by "creating body" between surfaces for each of them and splitting blocks? Does anyone have better approach? Please help!
manny9808 is offline   Reply With Quote
combustor, icem, meshing, meshing cylinder
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[ANSYS Meshing] Icem meshing queries Mfaizan ANSYS Meshing & Geometry 21 July 31, 2015 00:10
ICEM CFD-- ic engine combustion chamber meshing chetan mundhe CFX 15 July 22, 2012 19:34
