[ICEM] Creating surfaces for airfoil based on .igs and simulation space
Old   January 22, 2017, 10:03
Post Creating surfaces for airfoil based on .igs and simulation space
elias
eliaskhan is on a distinguished road
I solved the problem, so I edited the text.
eliaskhan is offline   Reply With Quote
Old   January 23, 2017, 03:27
elias
Meanwhile I created the surface for the blade and also for my simulation space. Thats the reason why i edited the first post.
I hope it works later on, when I start with the Mesh generating.
Before this I have still some problems.
I cannot line out my blade on my Wall side, so that the contour line is seen. As you can see in the pictures beginning with 02_Bad "free" of surface in the body itself, so you can look through ist.
The problem is, when i activate my wall, the contour of the blade is seen, but also its content resp. the volume.
How can i get rid of it? i tried to build up a new surface, but is does not work.
Thank you guys for your advices.
[General] Creating surface based on XYZ input and display data fron CGNS MarkHerskind ParaView 0 October 23, 2014 10:07
Terminate simulation based on probe Bernhard OpenFOAM Running, Solving & CFD 18 September 11, 2014 11:54
How is ANSYS CFX is related to RANS based Simulation Ramcad ANSYS 0 July 17, 2014 12:40
[OpenFOAM 1.6] How to run a simulation based on either DES or LES? imranazizahmed OpenFOAM Running, Solving & CFD 1 January 29, 2013 02:27
Zero mass jet simulation based on FLUENT Bonus Main CFD Forum 2 November 6, 2012 10:54
