[ICEM] Controlling growth rate from a curve into a surface |
Mandeep Shetty
Rep Power: 10 ![]() |
Hello everyone.I know we can control the growth rate from a surface into a volume by using tetra width and tetra ratio option.Is there something similar for controlling growth from a selected curve into a selected surface(not all the surfaces connected to the curve).Thank you.
Mandeep Shetty
Can someone help me please?
Mandeep Shetty
Any thoughts on the problem will be much appreciated. I have been stuck with the problem for quite some time now.
Mandeep Shetty
I have come to think that while there is no direct way of controlling the growth of surface mesh from a curve, by varying the curve mesh setup and surface mesh setup one can get a good mesh by trial and error. Also by getting the surface mesh after deleting a volume octree mesh seem to have helped me.
growth rate, icem, surface mesh |
Contours of custom surface rate (UDF and UDM) | cpassa | FLUENT | 2 | August 14, 2021 13:25 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] (Barely) acceptable growth rate | bongbang | ANSYS Meshing & Geometry | 2 | July 5, 2015 21:57 |
cell growth rate | nirupam | Main CFD Forum | 0 | January 17, 2006 06:50 |
