[ANSYS Meshing] The number of bodies are increased automatically when i open the mesh |
January 14, 2017, 18:40 |
Dear All,
I hope someone can answer to this strange problem. I have 28 bodies in my geometry. When i open it in the mesh, it automatically generates two more bodies which are not active. Also two bodies which are supposed to be separated are stuck together? Thank you |
January 15, 2017, 17:38 |
Rep Power: 14 |
check contacts between bodies
January 15, 2017, 17:44 |
Hi. I also think this must be the problem. one of the bodies have a very small intersection with the other body. when i open the mesh, those two bodies are identified as one body and the intersection surface is recognised as a body. Can you help me how i can solve this problem?
Thank you |
January 16, 2017, 22:00 |
Rep Power: 14 |
slice at that intersection may be so you distinguish between 2 bodies
mesh, unknown bodies |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
