[ICEM] Injector geometry and mesh
Old   January 12, 2017, 03:20
Default Injector geometry and mesh
Jason
AoJie is on a distinguished road
Hi everyone !
I'm working on an engine prototype that involves water injection in the cylinder. We are for now using modified fuel injectors to inject the water directly in the combustion chamber, and I would like to run CFD simulations to better understand the evaporation process.
I'm looking for a set of different injector geometries to run CFD simulations under ANSYS FLUENT and to compare them:
- GDI injector (inwardly and outwardly opening)
- Diesel injector (multiholes)
- PFI injector
- Air-blast injector
If someone had such kinds of geometries (or meshes) and could share them I would be very thankful (my email is ao.jie@outlook.com). At this point I have tried to build some geometries with Catia and to mesh them with ICEM CFD, but for now the results are not as good as I excepted .
The main idea is to compare different injection methods, such as cone shape sprays and compact spray shapes
I'm also open to any advice about geometry building and meshing .
Best regards !
AoJie is offline   Reply With Quote
Old   January 12, 2017, 17:09
Michael
majkers is on a distinguished road
Hey,
As far as engines are concerned I suggest using AVL fire. That software was designed for those kind of pursposes
Best regards
Michael
majkers is offline   Reply With Quote
Old   January 20, 2017, 03:22
Jason
Originally Posted by majkers View Post
Hey,
Best regards
Michael
Thank you for your advice. I considered using AVL fire before we start the project but finally decided to use FLUENT because I'm more familiar with ANSYS environment. But it turns out that it would probably be less time consuming to use an engine dedicated software .
I'm also considering using ANSYS FORTE, someone knows where to find tutorials ?
Old   June 3, 2018, 04:18
sanjay sajeevan
sanjaysajeevan is on a distinguished road
Hello ajoie,
si your work complete?
sanjaysajeevan is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
