[ANSYS Meshing] Need help in meshing complex fluid domain |
January 11, 2017, 13:51 |
Dinesh
Rep Power: 17 |
Dear Friends,
I am trying to mesh a complex fluid domain in ansys workbench . I want hex meshing for the domain. Can anyone help me out for achieving this. The fluid domain is attached for information and idea of the flow domain. Thanx in advance. Regards, Dinesh |
January 13, 2017, 14:56 |
#2 | |
Rep Power: 18 |
January 14, 2017, 11:24 |
#3 | |
Dinesh
Rep Power: 17 |
THANKS for ur reply. Actually those are three bodies not two. One is long cylindrical type and vertical cylinder is of two parts. So three bodies. |
January 17, 2017, 07:22 |
Rep Power: 11 |
You can try to use the multizone method. However, for a better control of the meshing process I would rather recommend you to split the domain in several bodies and mesh them using the Sweep method. So what you need to understand first is how the Sweep method works and how you can divide the domain using commands such as slice, extrude, revolve etc.
January 17, 2017, 22:51 |
Dinesh
Rep Power: 17 |
@Zbynek , Thank you so much.
The bodies are already separated. Body 1 is sweepable. Body 2 is inserted in body 3 and hence has irregular shape. So i am stuck up. I can share geometry file if any one want to help me......thanks in advance..... |
January 18, 2017, 04:39 |
Rep Power: 11 |
As I said, you need to understand what the Sweep method does. That it creates a surface mesh, sweeps it along a path and imprints the mesh on another surface. Imagine a simple cylinder standing on one of its bases. The Sweep method creates a surface mesh on one of the two bases, then sweeps the mesh along the height of the cylinder while slicing it horizontally to create cells. Finally, the surface mesh reaches the second base. Done. You will apply the same to your geometry. There are examples in the ANSYS tutorials where the Sweep method is demonstrated.
From your picture, it seems to me that the cylinder does not go through the whole arc volume. That would make meshing of the small volume below the cylinder problematic. Extend the cylinder till the lower face of the arc volume. |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? | acro | CFX | 15 | September 23, 2016 12:16 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
ANSYS CFX/Mechanical - fluid domain error | amsys | CFX | 1 | September 15, 2015 12:12 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
