[ICEM] Problem with Hexa-Dominant Mesh in a 3D Voxelized Model |
Rep Power: 11 ![]() |
Hi all,
I have imported the mesh from an STL file in ICEM 16.2. The mesh represents a 3D voxelized model of a rock. I am looking for the quickest possible mesh generation method for such a geometry. Since all the voxels have got the same size, I thought it could be a good idea to apply a hexa-dominant mesh of the same voxel size. Please see attached an enlarged screenshot of the model. The compressed mesh STL file can be downloaded from here. In the global mesh setup section, I set the max element to the voxel size. I also set the volume mesh type to the Hexa-Dominant. Finally, in the compute mesh section, I set the input to be the "Existing mesh". However, I got many of the following error message: Code:
expecting 2 shells on edge # # found 4 More explanation: I imported another STL file of the same model as faceted geometry (not mesh). I then made curves, surfaces, and body. However, I got the same errors when I tried to generate the hexa-dominant mesh. The compressed geometry STL file can be downloaded from here. Any help is appreciated. . Last edited by bidi; December 26, 2016 at 04:40. Reason: Adding the geometry and mesh STL files |
hexa-dominant mesh, icem 16.2 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
