December 23, 2016, 15:55 |
3D multizone sizing
Rep Power: 10 |
If anybody reads it maybe it is better to look at the picture first So, I am wondering if it is possible to make multizone meshing behave a little bit more like sweep meshing - I would like to have more control on resolution on Face A (see pic). What you can see is a part of an assembly i am meshing, I would basically like to create a sweep mesh in a part of a body A that is exactly the same as body B (half of a ring), but body A have some edges inprinted due to this cylindrycal part at the top, so I figured I will use multizone method. I used faces from body B as sources for multizone method at body A (not sure if that's correct - manual says source faces for multizone should be understood as target faces which is confusing for me). I tried two things - using sweep edges (red ones on top left pic) or Sweep element size method but none of them did what i wanted which is basically being able to generate exactly the same mesh like in body B. Should I create some edges on Face A to do that, do you have any suggestions? Thanks |
multizone meshing |
[ANSYS Meshing] Problems with creating a hex-uniform MultiZone Mash with Inflation | AnnaF | ANSYS Meshing & Geometry | 4 | April 19, 2019 07:24 |
[ANSYS Meshing] Viewing MultiZone Blocking Topology | siw | ANSYS Meshing & Geometry | 2 | March 8, 2014 04:13 |
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing | Far | ANSYS Meshing & Geometry | 6 | March 5, 2013 02:16 |
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing | Far | ANSYS Meshing & Geometry | 0 | March 3, 2013 11:17 |
[ANSYS Meshing] Growth ratio with body sizing | saisanthoshm88 | ANSYS Meshing & Geometry | 1 | October 12, 2012 08:51 |
