[ANSYS Meshing] Inflation in two bodies doesnt look like a single body |
December 20, 2016, 01:06 |
Onur Özcan
Rep Power: 12 |
Hi all,
I would like find out why inflation in two bodies doesnt look like a single body. At the attached two screenshots are seen. I have done one part including two bodies. Hint: Second one has the problem Any knowledge, or thought? Kind Regards, |
December 20, 2016, 01:12 |
Rep Power: 14 |
i could find the problem in second pic.
What issue do you have? sorry i couldnt figure it out |
December 20, 2016, 01:18 |
#3 | |
Rep Power: 18 |
December 20, 2016, 02:33 |
Onur Özcan
Rep Power: 12 |
I am using 14.5 version I couldnt see multibody inflation. But I have done by selecting two bodies in geometry and wetted faces of interest in inflation tab.
December 20, 2016, 02:41 |
Onur Özcan
Rep Power: 12 |
Well, thank you, as you can see there is no layer compression because of the place two bodies contact
December 20, 2016, 03:03 |
Rep Power: 18 |
What? I gave you link on flash video where it is shown how to get consistent inflation on multiple bodies. Have you watched it?
December 20, 2016, 03:15 |
Onur Özcan
Rep Power: 12 |
December 21, 2016, 04:21 |
#8 | |
Onur Özcan
Rep Power: 12 |
Please check watchfully regarding two screenshots. One of them has a layer compression in nozzle but the other one has an abrupt because of having two bodies. Inflation layer should follow like a single body. So, I need to split single body in order to see what some interior face values have in FLUENT. Inflation mesh couldnt like before. I hope you understand what problem is Kind Regards, |
December 21, 2016, 04:50 |
#9 | |
Rep Power: 18 |
December 21, 2016, 05:03 |
#10 |
Onur Özcan
Rep Power: 12 |
I really dont understand, inflations should be given in boundary layer regions. It shouldnt be given joint of two bodies.That is my thought. Velocity in fluid flow must not be 0 there or decreased by shear stress . That is what, layer compression screenshot is correct, one way or another.
December 21, 2016, 05:04 |
#11 |
Onur Özcan
Rep Power: 12 |
the attahced one.
December 21, 2016, 05:42 |
#12 |
Rep Power: 12 |
Hi. If I understand, you don't want 2 boundary layers in area you have indicated? Because I don't know whole geometry..
Sent from my GT-I9505 using CFD Online Forum mobile app |
December 21, 2016, 05:46 |
#13 | |
Onur Özcan
Rep Power: 12 |
December 21, 2016, 05:58 |
#14 |
Rep Power: 12 |
Some time ago, I have the same problem with my model of combustor (1 body) and let's say measurement domain (2 body). I had to create transition boundary layers for one duct. I did it in ANSYS Meshing module in Workbench using selective meshing if I remember correctly. Are you also using Workbench for this study?
December 21, 2016, 06:01 |
#15 |
Onur Özcan
Rep Power: 12 |
yes, I am using ANSYS-Meshing,as well.
December 21, 2016, 06:09 |
#16 | |
Rep Power: 18 |
December 21, 2016, 06:10 |
#17 |
Rep Power: 12 |
Ok, so selective meshing should help you. Firstly insert inflation option on one body which is primary and then insert inflation at second body. You have to do it separately. After that, do the same with creating meshing: First click right bottom on primary body and select meshing on selected body... and when mesh is created do the same on second body. Consequently, second mesh should be depend on first mesh.
December 21, 2016, 06:24 |
#18 |
Rep Power: 12 |
ozcaan, here is more explanation about it: https://www.sharcnet.ca/Software/Ans...b_meshing.html
December 21, 2016, 06:32 |
#19 | |
Rep Power: 18 |
December 21, 2016, 06:35 |
#20 |
Rep Power: 12 |
ICEM Ahmed Car body | Parms | ANSYS | 1 | December 22, 2016 22:19 |
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body | mo_na | OpenFOAM Meshing & Mesh Conversion | 3 | July 26, 2016 05:51 |
6DOF with floating body bounce back. | paka | FLUENT | 4 | June 6, 2013 12:32 |
[Need some advise] Am I doing right?? Simulating a rotational mixer | setasena | STAR-CCM+ | 4 | March 10, 2013 11:32 |
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. | aarvay | ANSYS Meshing & Geometry | 2 | May 11, 2012 12:15 |
