[ANSYS Meshing] Inflation in two bodies doesnt look like a single body |
December 21, 2016, 06:40 |
#21 |
Onur Özcan
Rep Power: 12 |
Thank you both
I am going to try what you told as soon as possible. I am going to let you know |
December 21, 2016, 06:48 |
#22 | |
Rep Power: 18 |
December 21, 2016, 06:50 |
#23 | |
Onur Özcan
Rep Power: 12 |
Velocity magnitude in that nozzle must be maximum,especially in nozzle center. Kind Regards, |
December 21, 2016, 06:52 |
#24 |
Rep Power: 12 |
Ok, maybe you have right because I didn't meet this in my study.
Sent from my GT-I9505 using CFD Online Forum mobile app |
December 21, 2016, 07:18 |
#25 |
Rep Power: 18 |
Really? So you wanna say that mesh on the image below is wrong? Because based on your words there're walls everywhere.
December 21, 2016, 07:42 |
#26 |
Onur Özcan
Rep Power: 12 |
Thank you mate
December 21, 2016, 08:26 |
#27 | |
Onur Özcan
Rep Power: 12 |
like max. angle, fillet ratio, fix first layer, gap factor ? Kind Regards, |
December 21, 2016, 14:08 |
#28 |
Rep Power: 18 |
December 22, 2016, 02:22 |
#29 | |
Onur Özcan
Rep Power: 12 |
I have watched it, it tells that max. angle should be increased to avoid stair-step in inflation. I have already done so, and defined it 175 degree, but ,it doesnt work . That is why, I have asked it |
December 22, 2016, 03:06 |
#30 |
Rep Power: 18 |
There're 3 different situations (3 locations) there and 3 different workarounds. Read notes carefully again.
December 22, 2016, 03:13 |
#31 |
Onur Özcan
Rep Power: 12 |
ok thank you
ICEM Ahmed Car body | Parms | ANSYS | 1 | December 22, 2016 22:19 |
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body | mo_na | OpenFOAM Meshing & Mesh Conversion | 3 | July 26, 2016 05:51 |
6DOF with floating body bounce back. | paka | FLUENT | 4 | June 6, 2013 12:32 |
[Need some advise] Am I doing right?? Simulating a rotational mixer | setasena | STAR-CCM+ | 4 | March 10, 2013 11:32 |
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. | aarvay | ANSYS Meshing & Geometry | 2 | May 11, 2012 12:15 |
