December 13, 2016, 10:24 |
Meshing problems using ICEM CFD
Rep Power: 9 |
Hi all,
I'm currently working on a paper. The goal is to simulate the air flow in a curved rectanglar tube. The problem is I'm a complete newby when it comes to CFD... I'm planing to mesh the whole thing using ICEM CFD. I've already got a CAD modell of the tube in Solidworks. I can import the modell via an .STL file into ICEM. I'm not realy sure how to get a good mesh for my problem. Could anybody of you guys try to help me out ? Thanks Tim |
December 13, 2016, 14:51 |
#2 | |
Rep Power: 18 |
December 14, 2016, 09:22 |
#3 | |
Rep Power: 9 |
Regring my problem, there re some good an some b news... I importe the whole file into the ANSYS-Workbench. I meshe it and calculated with an inlet-velocity of 200m/s. The results look good. But... it seems that I messed the mesh up. There aren't some "volumes" in the tube, as seen in the attached file. Can someone help me? Tim |
December 21, 2016, 06:50 |
Umberto
Rep Power: 12 |
How did you mesh your geometry?
Did you associate your edge boundaries to the geometry? I can't help without any further detail |
December 27, 2016, 06:03 |
#5 | |
Kushal Puri
Rep Power: 13 |
January 10, 2017, 10:00 |
Rep Power: 9 |
Hi everyone!
I changed from ICEM-Meshing to the Meshing-Tool within the Ansys-Workbench. In order to get a first approche I did a simple 2D-mesh. Looks good and results are also fine. The next step was to figure out how to do it in 3D. It look like that the mesh is only going on the solid part of my geometry and not on the "inside" where the fluid is supposed to be... I think it's due to the fact that the body is open on both sides? Can someone help? Thanks Tim |
January 13, 2017, 15:16 |
#7 | |
Rep Power: 18 |
help for a newbie, icem, meshing, student |
[ICEM] T Junction Meshing using ICEM CFD | selvam2487 | ANSYS Meshing & Geometry | 21 | July 25, 2017 13:04 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 11:28 |
icem cfd meshing problem | timothi61 | ANSYS | 2 | July 16, 2013 15:22 |
[ANSYS Meshing] Meshing problem using ICEM CFD | cgpa4 | ANSYS Meshing & Geometry | 2 | November 4, 2012 13:22 |
Problems of Icem meshing about Conical Forebody | raja2010 | ANSYS Meshing & Geometry | 2 | December 6, 2010 10:20 |
