December 7, 2016, 00:44 |
#21 |
Rep Power: 18 |
CFX handles such files easily. I don't see any problem
December 7, 2016, 02:25 |
#22 |
Abdullah
Rep Power: 9 |
i will try again!one thing how will i edit the mesh file in icem for different nodes and mesh density and how will i check the blocking method you applied? when i open the mesh file you send i cant edit it i want to improve the quality of the mesh and define y + block need further work thats why i need a file which i can edit in icem
December 7, 2016, 02:44 |
#23 | |
Rep Power: 18 |
December 7, 2016, 10:14 |
#24 | |
Abdullah
Rep Power: 9 |
i want to learn if you can tell me the software you use i will learn and try it by myself . |
December 7, 2016, 11:07 |
#25 |
Rep Power: 18 |
December 8, 2016, 09:00 |
#26 |
Abdullah
Rep Power: 9 |
December 8, 2016, 09:32 |
#27 |
Rep Power: 18 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
Meshing a Mixing Plane in ICEM | Will Anderson | ANSYS Meshing & Geometry | 2 | November 9, 2010 10:16 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 18:08 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 11:09 |
ICEM meshing question | gsbhatia89 | ANSYS Meshing & Geometry | 5 | June 14, 2010 09:24 |
