November 21, 2016, 01:40 |
Weird Meshing Problems
Rep Power: 10 |
Hello everyone, I attached pictures of the mesh issues I'm running into. Not only is the mesh uneven across the length of the pipe, but at the end of the pipe there is a weird orange layer of mesh that seems out of place.
When I load into Fluent it gives this weird bubble of mesh. Do you know what's wrong and how I can fix it? Thank you. |
November 21, 2016, 02:41 |
Paritosh Vasava
Rep Power: 22 |
Onur Özcan
Rep Power: 12 |
check your changes in DM (merges, etc.)
check your external geometry extension (if it is ) check your model tolerance check your facet geometry make finer mesh |
November 21, 2016, 03:08 |
Rep Power: 10 |
November 21, 2016, 03:16 |
Onur Özcan
Rep Power: 12 |
delete>body delete in DM
November 21, 2016, 03:24 |
#6 | |
Paritosh Vasava
Rep Power: 22 |
I recommend that you use preview slider to see where it is going wrong. It plays like an animation and when it goes wrong the faces should turn red. Unless we see the complete model it is bit tricky to give you suggestions. |
November 21, 2016, 05:30 |
Rep Power: 10 |
Ok, I went back into spaceclaim and now everything is working fine. Thank you guys so much!
ansys, fluent, mesh, weird |
[ANSYS Meshing] I have Meshing Problems Ansys 16 | Leocali | ANSYS Meshing & Geometry | 1 | April 21, 2016 18:36 |
[ICEM] Problems with meshing of wind turbine | Dosis | ANSYS Meshing & Geometry | 14 | November 13, 2012 05:41 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Gambit problems around meshing models | mashinsazi | Main CFD Forum | 0 | April 11, 2011 06:11 |
Meshing problems using Gambit | Vianney | FLUENT | 4 | May 30, 2009 03:45 |
