[ICEM] Association of blocks and vertices in ICEM
Old   November 10, 2016, 20:33
Default Association of blocks and vertices in ICEM
Luka Vincekovic
lukacro is on a distinguished road
Hi people,
I am trying to mesh a separator which is actually a combination of joined cylinders. I have a problem, as showed in the pictures, with this small pipe around which I have to generate mesh. I really don't know the solution, I attached the blocking and associations of the blocks but I am not sure if this is the right approach.
Can you make in ICEM these "guidelines" for mesh around circular object, because as now, when I have a circular object inside of another circle and it not in the centre then, when it come to ICEM, I am pretty lost.
I would use any kind of advice. THANKS!
lukacro is offline   Reply With Quote
Old   January 23, 2017, 02:18
Vinod Jadhav
vinodj1993 is on a distinguished road
Originally Posted by lukacro View Post
Hi people,
Check out this link Unexplained changes of mesh quality and blocking approach
vinodj1993 is offline   Reply With Quote
association, blocking, icem
[blockMesh] blockMesh - numbering of vertices with multiple blocks AmRo OpenFOAM Meshing & Mesh Conversion 6 May 16, 2016 06:05
[blockMesh] blockMesh problem with blocks with vertices adrieno OpenFOAM Meshing & Mesh Conversion 3 March 23, 2016 04:35
[ANSYS Meshing] Difference between merged blocks and adjacent blocks which are not merged Shruti ANSYS Meshing & Geometry 0 July 12, 2015 18:44
[blockMesh] block with 6 vertices Hale OpenFOAM Meshing & Mesh Conversion 1 October 5, 2013 09:00
[ICEM] Deleting VORFN blocks in ICEM CFD Sai Swaroop ANSYS Meshing & Geometry 5 October 18, 2011 11:26
