[ICEM] Differenz BCs after mesh rotation
Old   November 10, 2016, 11:09
Default Differenz BCs after mesh rotation
MadMax is on a distinguished road
Hey everyone,
I have a small problem with my ICEM mesh.
Just for comprehension:
I have a geometry (periodicity 30°) where I have one inlet and one outlet per periodicity. So far so good. now I want to eliminate every third inlet. I wanted to rotate the Mesh and define every new created inlet as a wall.
So here is my problem:
first of all after my rotation there are many problems if I check the mesh for periodicity as it says no periodicity defined.
the second problem is that i cant redefine the inlet as a BC because I only have one Inlet part after the rotation.
Thanks in advaance,
Cheers,
Max
MadMax is offline   Reply With Quote
bcs, icem, rotation
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
