[ICEM] How to set bondary conditions after complete mesh generation? |
Matheus Castro Bachega
Rep Power: 0 ![]() |
Hi everybody!
I need a help to create boundary conditions on ICEM in my mesh. Actually, i am trying import my mesh to openFOAM, so, before i have to set a boundary, i guess. Please, i am new in CFD analysis and your help would be precious, p.s: i am working with 2-D pipe junction tutorial. (how to create mesh in ICEM and import to openFOAM). |
Gwenael H.
Rep Power: 20 ![]() |
Hi Matheus,
You just need to specify the BC in the output mesh tab. For OpenFoam mesh you should select the Fluent output solver (first tab > solver output). Once you’ve selected the solver you move on with the second icon “Boundary Conditions”. On the pop-up window you can specify various BC. In your case as you’re in 2D you should have only “edges” type BC. Once the BC done, regenerate the mesh and then export it to .msh (fluent mesh type). Then use the mshToFoam and you’re done ![]() |
Gweher,
Thanks very much! your help was very helpful for me ![]() |
bondary, bondary conditions, cfd analysis, icem, mesh 2d |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
