[ANSYS Meshing] Reducing mesh non-orthognality for bluff body with sharp edges |
November 4, 2016, 17:49 |
Bashar
Rep Power: 11 |
I am working on a mesh of of plate with sharp edges at the end, for my LES simulation in openFaom. I am using ANSYS for the meshing, unfortunately due to the sharp edges, when I convert the mesh to the openfoam I get a very high non-orthogonality (above 80). I am using cutcell with inflation layer around the plat , as shown in the attached pictures. I tried to play around with the growth rate and the angle in the general mesh advance options and increase it from 140 to 180. I have a reduction in the non-orthogonality but by very small amount. Is their any advice how to improve the mesh around the sharp edges? |
November 16, 2016, 11:00 |
Bashar
Rep Power: 11 |
I tried to use different technique than the cutCell. It also didn't give me a good mesh.
November 18, 2016, 03:28 |
Onur Özcan
Rep Power: 12 |
it seems good actually, I have a coarsener mesh than you did.
Growth rate is relevant to first layer thickness and total boundary layer thickness |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 10:12 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
