call for help in meshing using ice engine fluent |
October 27, 2016, 07:48 |
Aseel
Rep Power: 10 |
Hello everyone
can anyone help me fix this issues which occur during meshing process using ice engine ?? 1- after i set up the mesh set up , tow error occured saying that "Some faces of exvalve1-ib-body does not belong to any Named Selection. They might belong to: intf-int-exvalve1-ib-fluid-ib" as you can see in the picture . 2- after meshing complete, it was not successful and many errors occurred as well . you can see in the picture attached can anyone help identify the error and fix it ,please?? i really i don't know how to fix it at all i will really appreciate your help thank you |
January 18, 2018, 05:33 |
Nick Gill
Rep Power: 8 |
I have the same problem and am trying to work through it.
Let me know if you found a solution please. |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
Tutorial 12. Cold Flow Simulation Inside an SI Engine. Fluent 6.2 | hesham | FLUENT | 0 | February 13, 2016 09:24 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
Gambit Meshing export to fluent minor problem | John c. | FLUENT | 2 | February 6, 2002 17:52 |
