[DesignModeler] not able to generate surface in design modeler |
October 20, 2016, 05:11 |
saurabh kumar gupta
Rep Power: 10 |
Hi all,
i am doing a simulation where two rectangular blades are inserted into a rectangle. these blades are inserted in such a way that no fluid can pass. so one vertex of each blade is coincident on each other. and diagonally opposite vertex is coincident with sides of rectangle. so when i am generating a surface it is giving a warning saying no close sketch. i am attaching my geometry here so that you guys can look into it. any kind of help will be appreciated. Thanks in advance this is link for my geometry. https://drive.google.com/file/d/0Byn...ew?usp=sharing the error message is following in the image |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
Baffle in the cubical domain in design modeler | eslam | CFX | 6 | March 16, 2018 09:12 |
[Other] Connecting 3D bodies in Ansys Design Modeler | chipper | ANSYS Meshing & Geometry | 4 | January 25, 2018 10:45 |
[DesignModeler] Rotating an imported part in Design Modeler | mikko | ANSYS Meshing & Geometry | 2 | November 30, 2015 01:23 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
