[ANSYS Meshing] Problem with Inflation Descreasing Mesh Quality |
October 17, 2016, 22:46 |
Wildan Arief
Rep Power: 10 |
Hello everyone,
Right now I'm working on a steam ejector project. I was asked to create the fluid flow simulation. And currently I'm stucked with the Inflation problem. I know I can't ignore the inflation since it's the fluid flow analysis. From pic 1-3 (attached on Geometry 1-3.zip), you can see my whole geometry. When I use global mesh only (without inflation), the skewness and orthogonal quality seem good (max 0.79 and min 0.24, respectively) - see pic 4-5 in Skewness & Orthogonal Quality 4-8.zip. But when I insert the inflation, the max skewness: 0.91 and min orthogonal quality: 0.013!! It's decreasing drastically! (see pic 6-7 in Skewness & Orthogonal Quality 4-8.zip). I've tried to change the inflation options (i.e. smooth transition, total thickness, first layer thickness, changing the layer height, growth rate, etc). Also I've modified the mesh sizing options (global mesh) - i.e. advanced size function, relevance center, smoothing, min-max size, growth rate, etc. But all of it doesn't improve the mesh quality significantly. FYI, I've tried the sweep, multizone, tetrahedrons, hex dominant, you name it. But still it doesn't solve my problem. I really need your help to solve it. Thank you very much. I really appreciate your help. Cheers. Geometry 1-3.zip Skewness & Orthogonal Quality 4-8.zip |
October 18, 2016, 06:08 |
Paritosh Vasava
Rep Power: 23 |
Can you also upload the workbench files somewhere and post the link? It will be easier to spot the problem rather than making mesh from scratch.
October 18, 2016, 21:49 |
#3 | |
Wildan Arief
Rep Power: 10 |
I have uploaded the .meshdat files here: https://www.dropbox.com/s/38e5cwy6ne...h.meshdat?dl=0 From my latest trial (link above), the orthogonal quality is improved a bit (min orthogonal 0.042). I know it's still far from the ideal value. FYI, I am using ANSYS 16.2. Hopefully you have the same or newer version so that you'll be able to open it. Thank you very much for your help, sir. Regards |
October 19, 2016, 00:58 |
Paritosh Vasava
Rep Power: 23 |
Not the .meshdat files but the .wbpj file and corresponding folder.
Check the folder where you have saved your workbench setup. There should be yourProject.wbpj file and a folder yourProject_files (Here yourProject= the name with which you saved your workbench files). |
October 19, 2016, 01:44 |
#5 | |
Wildan Arief
Rep Power: 10 |
https://www.dropbox.com/s/ckfji9haln...oject.rar?dl=0 |
October 20, 2016, 02:41 |
Paritosh Vasava
Rep Power: 23 |
I did not find any special setup in your workbench files except the inflation (that too had only one layer!!). You will need more setup if you want a better mesh.
I tried a quick setup and everything, including inflation, worked quite nicely for me. I suggest that you try the following:
October 20, 2016, 05:28 |
#7 | |
Wildan Arief
Rep Power: 10 |
However, after doing multiple setups, I got worse orthogonal quality (best result I've got is 0.18, and it's not improving with fluent TUI commands). I've attached 'em below. Could you by any chance attach your setup including min-max sizing and inflation setup? I would really appreciate your help. Again, thank you very much. |
October 21, 2016, 05:13 |
Wildan Arief
Rep Power: 10 |
UPDATE: Finally I got the same value as yours in FLUENT. I hope this is gonna work. Thank you very much, Mr. Vasava!
October 21, 2016, 06:42 |
#9 |
Paritosh Vasava
Rep Power: 23 |
I am logged in to ubuntu right now and dont have access to Ansys. But I am glad that your mesh settings are working out.
October 21, 2016, 07:06 |
#10 |
Michele
Rep Power: 10 |
hi everyone!
I've exactly the same problem: the mesh quality drastically decrease when I insert the inflation layers. Any suggestion? My solver is CXF. I've used as size function proximity and curvature. below the photos of the geometry and of the quality. I'm working on a quarter of the full geometry thanks to the symmetry. here the proj file (v 17): https://1drv.ms/f/s!AlY0liGuZwHig8gzMBTNug38m3oE2w Thanks Michele |
October 24, 2016, 01:21 |
#11 |
Paritosh Vasava
Rep Power: 23 |
Michele, I have no experience with CFX (and no access as well) and I do not know if CFX has TUI commands to improve mesh qualities just like fluent. You can try suggestions I gave to Wildan and see if they workout for you.
I will have a look at your case with fluent when I have time. |
October 24, 2016, 08:09 |
#12 | |
Michele
Rep Power: 10 |
sure,I've tried to follow the suggestions that you have gave to Wildan but I haven't obtained good results. I have no idea how to use (if they are in CFX) the TUI commands. Michele |
October 25, 2016, 01:18 |
#13 |
Paritosh Vasava
Rep Power: 23 |
Michele, I am unable to download your case files. I tried thrice and it stopped downloading midway. Either your case files are way too big or it my office internet. Anyways, Can you upload it somewhere else? Also compress the files.
October 25, 2016, 06:17 |
#14 | |
Michele
Rep Power: 10 |
Now I have put in the same folder also the meshdat file called "mesh", compressed and not. Thanks Michele |
October 26, 2016, 03:51 |
#15 |
Paritosh Vasava
Rep Power: 23 |
Firstly, I checked the mesh quality for your mesh with fluent and it passed all the checks. Of course the mesh quality was low (0.013) but with TUI commands I could get it to 0.103674. So your mesh (after TUI manipulations) should be good enough for calculations.
Next, I tried a quick setup with my own recommendations and again I could get a mesh (after TUI manipulations) which was alright for calculations. Here is what I did:
Again, I dont have CFX so I dont know if there are ways to improve mesh quality in CFX. I dont even know how to check mesh quality in CFX. So, lets wait for someone who is expert on CFX to give you a better opinion on this one. |
October 26, 2016, 14:23 |
#16 | |
Michele
Rep Power: 10 |
Unfortunately I'have never used Fluent and TUI to mesh, but, because you have obtained what I want, I'm trying to understand how to use it. If it is possible, could you send me some screenshot of the parameters that you have set in fluent to understand more fast where the commands are? Thank you Michele |
October 27, 2016, 02:55 |
#17 |
Paritosh Vasava
Rep Power: 23 |
Fluent TUI commands are pretty simple to use. You may first want to read what exactly they do.
For example if you want to improve mesh quality you can follow these steps:
Also after executing the commands if you dont see any improvement in the mesh then you will have to go back to ansys meshing, change mesh and try something else. |
October 27, 2016, 11:06 |
#18 | |
Michele
Rep Power: 10 |
March 2, 2019, 12:11 |
#19 |
Alamu
Rep Power: 8 |
The mesh quality can be improved by
1. Partitioning the domain using simple shapes as square, triangles and use face meshing by matching equal no.of. divisions. 2. Give small sizing for edge sizing, face sizing and body sizing. The skewness and aspect ratio comes down. Max skewness 0.91 is not bad. |
March 4, 2019, 02:08 |
#20 | |
dacdung
Rep Power: 7 |
Is it possible to split domain at free surface? I am trying to simulate the water entry problems using Ansys CFX (2-way FSI). As I know the mesh quality of free surface is important to capture properly water interface during impact. So I have tried to divide the fluid domain to two blocks to mesh independently, but it does not work (i.e. CFX could not find the interface). Could you please help me to make a good mesh at the expected region (free surface), without split fluid domain? Thank you in advance! |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[ANSYS Meshing] problem with mesh quality | yaseen wsu | ANSYS Meshing & Geometry | 5 | April 29, 2016 02:16 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ANSYS Meshing] Inflation - Mesh Quality | saideepakb | ANSYS Meshing & Geometry | 0 | May 26, 2012 09:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
