[ANSYS Meshing] Turbulent flow, no zero velocity at wall. |
October 17, 2016, 21:44 |
skywalker
Rep Power: 10 |
Hello all,
I have been running a turbulent flow problem. The output velocity profile however, doesn't show zero velocity at walls!. Dimension D=0.02m, L=10m I am using an FLT of 1e-7m, 25 layers and 1.24 growthrate. circumfrential element size is 1e-3m and sweep size is 0.026m. I have written a matlab m file and produced the correct velocity profile for this problem using viscous boundary layer y+=u+ for y+<5 and a standard log law for the rest of the flow. I found out that the viscous sublayer (y+=5) is about 1.4e-4 m. The aspect ratio for the thin elements near the wall are 260 K! which is bothering me but not much that I can do about it. I thought I should run double precision, but the U-mom and V-mom solution fail (F). Please help me. |
element quality, meshing 3d, turbulent boundary layer |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 11:34 |
3D Velocity profile for turbulent flow | Kirill | Fluent UDF and Scheme Programming | 3 | July 17, 2014 09:42 |
Turbulent cyclic pipe flow, wall functions and y+ | clyde | OpenFOAM Running, Solving & CFD | 3 | March 17, 2014 07:08 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
