[DesignModeler] Easiest way to create helical threads for a steel cable |
Rep Power: 9 ![]() |
Hey there!
Basically, I need to model steel cables made of one central straight fiber and sorrounding helical fibers around it (2 more layers, in fact). I've been digging everywhere but still can't find a proper solution. So far, I've thought I could create a .txt file with the coordinates for the center of each helical fiber and then use SWEEP, with a round profile of the diameter os the sub-cable and the path from a line created with the point imported from the .txt file with th coordinate. I don't know if there's an easier way. Nonetheless, I'm still struggling with the SWEEP command since I can't create a proper sketch from the line made of the points I imported. I also don't really know how to create a line from all the points without the need to select each point one by one. Any feedback is welcome! Edit: I figured I can create a 3D curve with the coordinates points but I can't convert it into a sketch to make is usable as a path for the SWEEP. Edit2: Finally realized you can use sketch with a body line. I worked fine. Last edited by ISV; October 17, 2016 at 19:12. |
cable, helical, steel, wire |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
create helical ribbon | hamina | FLUENT | 9 | October 12, 2012 06:03 |
How to create a variable-pitch helical sweep in Designmodeler (v11.0) | dgasperi | ANSYS Meshing & Geometry | 0 | August 13, 2009 13:11 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
