[ICEM] Premesh refinement problem - Penetrating elements
Old   October 16, 2016, 14:26
Default Premesh refinement problem - Penetrating elements
Johannes Hall
yonpanman is on a distinguished road
Hello everyone!
I am trying to mesh a simple domain structured domain that has a volume of local refinement. I am trying to do this with the premesh refinement tool and everything looks fine until I convert the mesh to unstructured and run a mesh check.
First I get a message of uncovered faces, From what I have understood from other posts in the forum this has to do with the association of the faces to surfaces (is this correct?). ICEM seems to be able to fix this problem however.
The second problem that arises is penetrating elements. Now from what I have understood this is elements from one surface that penetrates another surface. In the attached picture the problem elements are shown. I don't really get what's causing this this problem though.
Does anyone have experience with this and have any tip on how to solve this problem? I have tried to associate edges to curves and surfaces and faces to surfaces but this problem seems to continue to exist.
If anyone has an idea I would be very thankful!
Best regards
yonpanman is offline   Reply With Quote
Old   October 18, 2016, 03:39
Johannes Hall
Hello again!
Any help on this topic would be greatly appreciated! I tried to make it conformal again with the mesh merging alternative but this does not work neither. I think that the main problem is the surface where the refined and the non refined mesh sort of meets.
Surely someone must have an idea at least?
Best regards!
icem, penetrating elements, refinement, uncovered faces
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] problem with snappyHexMesh kanes OpenFOAM Meshing & Mesh Conversion 10 January 26, 2016 07:11
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 09:06
