October 12, 2016, 07:53 |
Solid Body after Boolean
Mert
Rep Power: 10 |
I am working on a submersible pump analysis and I am using rotating frame motion. I modeled my pump impeller(solid), frame(fluid) and a static domain for relative motion(fluid) in SolidWorks. When I import my drawing to Design Modeler and substract the solid impeller with boolean command, there is still a solid part occurs in cell zone editing in Fluent. The next day I imported another geometry and apply boolean, there were only the fluid domains as it should be. I couldn't find an explanation for that, anyone has an idea ? |
October 17, 2016, 07:43 |
Mert
Rep Power: 10 |
Nobody knows ?
boolean, boolean subtract, cell zone, frame motion, import models |
Wing FSI simulation: Shell elements or 3D solid body? | frossi | CFX | 3 | June 15, 2016 20:02 |
Solid Body Motion | Lynus | Autodesk Simulation CFD | 0 | September 7, 2015 05:30 |
How to visualize the solid body in multiphase flow grid? | asoltoon | OpenFOAM Post-Processing | 2 | February 2, 2013 12:40 |
Why the body is solid but not fluid when the NX file import into the DM? | ddx | ANSYS Meshing & Geometry | 1 | December 27, 2010 22:13 |
cooling a solid body | Ralf Schmidt | FLUENT | 1 | April 16, 2007 10:54 |
