[ICEM] Penetrating mesh after rotating, 3D impeller, rotating zone |
October 12, 2016, 07:11 |
dave
Rep Power: 13 |
I read this forum and I have found many answers about my CFD Simulation problems, but now I need Your help. I'm trying to model 3D radial fan and i have problem with 7 blade impeller which is meshing in ICEM CFD. I meshed 1/7 of my impeller (actually space between two blades + front and back disc + 3mm space above; all of this is my rotating zone). All elements are hexa. I adds help geometry directly in ICEM (curves only ) to improve mesh by egde association. Technique Block by block, Pre-Mesh/Projected Edges is converted to Unstruct mesh. Now, I'm trying to copy my mesh 6 times by rotate (~51.4286 degree)/ Merge Nodes/Automatic/ delete duplicate elements; when check mesh i got errors about: Dulicate elements, Non-Manifold vertex and Penetrating Elements and i cant figure it out how should I done with this because after importing mesh to fluent I got errors. My questions: 1) How can i resolve problem whit penetrating elements? 2) Is this properly technique of modeling impeller/rotating zone? 3) Is this mesh good quality or should I improved it more and how? I attached files from ICEM. Thanks for your time. I would really appreciate the help. |
October 22, 2016, 13:36 |
dave
Rep Power: 13 |
Anyone can give me an answer?
October 26, 2016, 11:04 |
dave
Rep Power: 13 |
Hi Far, thank you very much for your response.
My whole model of radial fan looks like in attached pictures. It contains parts: body, inlet pipe, and impeller. That cylindical part is a part of fluid in body/impeller. All of these are already modeled as fluid and between these parts are interfaces. There is no solid part. I mesh them separately i ICEM. Only impeller will be rotational part. I meshed my impeller as 1/7 part of impeller because it have 7 blades. Now I'm trying to rotate mesh x6 to get full impeller but i got errors from first post. Is this good strategy or should I try different? BTW I already have 2D model of radial fan based on the same strategy. In 2D I also rotating mesh 51.4286x6 degrees to get full impeller and i don't have any errors. Maybe in 3D it's different? |
impeller, penetrating elements, rotating mesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Rotating mesh in a moving reference frame | mafz1g11 | FLUENT | 1 | March 23, 2019 01:13 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 04:02 |
How to deal with a rotating shaft which is not in the rotating zone. | sharonyue | OpenFOAM Running, Solving & CFD | 0 | May 5, 2013 21:00 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
