October 11, 2016, 15:30 |
Sliding mesh
Reza
Rep Power: 10 |
Can someone please tell why do i get only lines in my fluent contours of velocity ?
I think its because of mesh am i right ? Here is the PicMesh11.jpg |
October 12, 2016, 07:09 |
Paritosh Vasava
Rep Power: 23 |
Because you are plotting only contour lines. If you select 'Filled', the remaining space will be filled accordingly.
The accuracy of contours depend on the mesh size. Finer then mesh, smoother will be contour lines. Last edited by vasava; October 12, 2016 at 07:11. Reason: typo |
October 12, 2016, 08:17 |
Reza
Rep Power: 10 |
Thank you for your reply,
I have fixed the problem with your advice,Thank you again. Do you have any advice for checking mesh, i only check the skewness is there anything else i need to pay attention ? |
Dynamic Mesh and Sliding Mesh Simultaneously | reynold92 | FLUENT | 2 | May 9, 2015 16:26 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
dynamic mesh and sliding mesh | nasser | FLUENT | 0 | November 1, 2005 03:37 |
