[DesignModeler] Cutting into Surface of a Body
Old   October 10, 2016, 08:21
Default Cutting into Surface of a Body
AC
AC1993 is on a distinguished road
Hi
Ive just started to learn how to use Design modeler, ive encountered a problem... I was wondering if anyone knows how to cut holes (acting as an inlet/outlet) into a body without going all the way through the body. Ive been experimenting with the different functions but i cant get it to work. Ive had a look online but they are all for cutting through the body..
Thanks for your help
-AC
AC1993 is offline   Reply With Quote
Old   October 10, 2016, 19:35
Kapi is on a distinguished road
hey man!
Can I please suggest you to go thru help section in Ansys?
Its a small thing and you will find answers there,
Check help and if you dont find anything then you come here and ask
we will be happy to help!
Anyways , here is your answer!
Create hole geometry at location,
Extrude it to given depth in body
remove it from body!
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   November 4, 2018, 21:04
Muha
malasi4 is on a distinguished road
Originally Posted by Kapi View Post
hey man!
Cheers
KAPI
Dear Kapi,
I am having the same issue. I created a circle on a surface, then i used cut material through all, but the thing is that i am still having a body. Therefore, when i remove it from bod, it deletes the whole body including the circle. Any comments will be much appreciated
malasi4 is offline   Reply With Quote
beginners, design modeller, designmodeller, geometry ansys
[DesignModeler] how to subtract a surface body from a solid body? yahya ANSYS Meshing & Geometry 4 January 7, 2013 12:00
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
Free surface and moving body Steve Siemens 4 August 20, 2004 12:06
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
