[ANSYS Meshing] The Generated Mesh Does Dot Capture The Edges of Wing
Old   September 20, 2016, 06:53
Default The Generated Mesh Does Dot Capture The Edges of Wing
mohammadreza
mrh111 is on a distinguished road
Hi everybody,
I have used "skin/loft" to generate a wing with 4 airfoils but when I mesh the wing, the generated mesh does not capture the edges of wing.
I use Curvature for advance size function and I've increased Relevance up to 100 and adjusted Relevance center to fine and decreased the Curvature Normal Angle and also I have decreased the face element size but it wouldn't efficient.
I hope someone know the solution.
Thanks in advance.
http://uupload.ir/files/rav5_photo_2...0_14-15-00.jpg
http://uupload.ir/files/82sv_photo_2...0_14-15-07.jpg
http://uupload.ir/files/ec2i_capture5.jpg
http://uupload.ir/files/u8a8_capture.jpg
mrh111 is offline   Reply With Quote
Old   September 21, 2016, 02:42
Paritosh Vasava
vasava will become famous soon enough
  1. Change the advanced size function to 'fixed'.
  2. Change face sizing behavior to 'hard'.
  3. You can also introduce edge sizing for all the edged [optional]
  4. Initially disable the inflation layer. Once you get the mesh you desired, you can turn it back on.
Try these and let us know how it went.
vasava is offline   Reply With Quote
Old   September 21, 2016, 09:53
mohammadreza
Vasava, I really appreciate your suggestions.
I tried them. After regenerating the mesh with default size, problem solved.
But some roughness arose when I decreased the element size of edges and refined the mesh.
I'll upload the geometry, its very kind of you if you look at it.
If you couldn't open the file let me to change the upload center site.
thanks a lot.
http://s8.picofile.com/d/8268155584/...ojection3.agdb
Old   September 22, 2016, 02:46
Paritosh Vasava
I will see, what I can do.
Old   September 26, 2016, 06:15
Paritosh Vasava
I am using spaceClaim and am not able to open your CAD file. Could you convert it to STL or STEP file?
Old   September 26, 2016, 06:53
mohammadreza
yes, sure, I've just zipped it.
http://up.persianscript.ir/uploads2/1226-Geom2.rar
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 10:33
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
