[ANSYS Meshing] refining the leading edge of a wind turbine blade |
September 9, 2016, 10:50 |
david
Rep Power: 14 |
I am using the octree volume mesher in ICEM to mesh a 3-blade wind turbine. I imported the STL file but I cant seem to split the facets but that is not the main issue. The main problem is the leading edge (see the pics attached). Is there a way to refine the leading edge so that i dont get 'bumpy' meshes in that region? |
September 9, 2016, 17:35 |
B.H.
Rep Power: 12 |
If the geometry has a curve (or if you build one) along the leading edge, you can use Mesh --> Curve Mesh Set Up to define the sizing of the cells growing off of the leading edge.
I also noticed that your trailing edge has little nicks in it. I would also refine the trailing edge cells and if you still have those nicks, then maybe play around with a lower value for your Edge Criterion (one of the options when you set up your octree volume mesh). |
May 9, 2018, 19:35 |
gereksiz
Rep Power: 11 |
Dear all,
I was searching my problem in the group and I found this post which had exactly the same issue. The only problem is that I am using ANSYS Meshing and the proposed solution is for ICEM. I have been looking around for a long time (I should say that I am a beginner) and couldn't find a solution yet. I have changed the curvature normal angle, created a new surface to refine it more, adding edges but nothing has worked so far... I have also other parts in the CAD which are curved but I didn't have problem on those regions. So I am not sure if there is a way to fix it or I am missing an important parameter like in the ICEM case. I am also adding a picture of the surface mesh. I am hoping that you might help me. Best, |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ICEM] blocking 3D wind turbine blade | chuky_abc | ANSYS Meshing & Geometry | 34 | March 25, 2016 23:44 |
Analysis of Wind turbine blade ( 3D aerofoil) by Ansys 12 | rsskarthikeyan | FLUENT | 5 | October 13, 2012 23:29 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 17:44 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 03:33 |
