[ICEM] Circular Tangential Inlet Mesh Distorted
Old   September 8, 2016, 12:09
Default Circular Tangential Inlet Mesh Distorted
Amir
amirkh is on a distinguished road
Hi
I am having trouble making a decent HEX mesh for the tangential inlet geometry I have. I have been trying to follow the similar steps shown in this tutorial: https://www.youtube.com/watch?v=dalhTs4-0-c
although the difference is that the tutorial has a square inlet while my geometry is circular inlet.
I added an O-grid to the circular inlet and blocks looks decent, see the attached images, however when meshing, it seems the projection from the circular face at the begining of the inlet toward the interface to the main body take a twist which results to an awful distortion in mesh. One can follow the line along the length of the inlet and see how it is twisted.
My question is, even though the blocks looks decent and straight, why mesh projections take a twist and how to fix it.
Thanks
File Type: jpg ICEM_Blocks1_at_interface_opposite2.jpg (66.4 KB, 21 views)
amirkh is offline   Reply With Quote
Old   September 9, 2016, 06:25
Sebastian Engel
bluebase will become famous soon enough
Hi Amir,
i firstly suggest you to check your associations the flange and nearby curves. Also move the vertices to their approximate location in the final mesh.
Use "Scan planes", "Show Association", and Mesh Quality to understand the flaws.
Though i have some doubts, that a good quality mesh blocking will be as simple as it is in your case.
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   September 9, 2016, 19:14
Amir
Thanks Sebastian,
You were right, I had issue with my associations, I have made some changes and it has improved my mesh. As you said I still have some small problem at the tangential inlet which seems to be the case for these kind of geometries.
Thanks for taking the time and writing a post here
Cheers
Amir
Old   September 9, 2016, 19:25
Sebastian Engel
Hi Amir,
you may have a look at page 95 of this guide: https://docs.google.com/file/d/0ByIL...BQT3pQMjQ/edit
There is explained how to do a volute's blocking. This seems like a very similar case to the cyclon's attached pipe. I know this will be tricky to do.
Unfortunately, this is all i can help right now.
With regards,
Sebastian
Old   September 9, 2016, 19:32
Amir
Thanks Sebastian,
Yes, following the YouTube tutorial, I think I did those steps recommend in the the slide. The problem is my geometry is 3D with a circular pipe coming to the main tank so the interface becomes an egg shape edge with sharp edge that is the most distorted meshes right now (although much improved since yesterday)
I think I will give it a try and run it and see how it goes.
Danke
Cheers
Amir
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 20:34
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Variable inlet size with only one mesh lindner OpenFOAM 4 March 25, 2010 10:15
