[ANSYS Meshing] Selecting multible faces at once |
September 7, 2016, 10:20 |
Þórólfur Björn Einarss
Hi
I have a cylinder with multitude of very small cylinders protruding radially out of the cylinders wall (See figure). I want to select all the small cylinders' top surface in one go. Is that possible? Best regards Thorolfur |
September 7, 2016, 22:15 |
Rep Power: 14 |
try to change axis and see if you can select all small from one side.
Otherwise its not possible unless you create script for it. I wouldnt personally create script for such small thing! |
multible, namedselection, select, surface |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
