[ICEM] Bad 3x3x3 Determinant while mehsing annlar gap |
September 5, 2016, 11:17 |
Niklas
Rep Power: 10 |
Hello everybody,
I´m currently meshing an annular gap as shown in the picture. At every wall I need a spacing of about 2e-6 in order to get y-plus values around 1. But when I use a spacing below 5e-6, the 3x3x3 Determinant drops. In the picture are shown all the elements with a determinant under 0.05. All of them are located at the outter wall Does anybody know why this is happening? |
September 7, 2016, 03:14 |
Sebastian Engel
Rep Power: 21 |
Hi Niklas,
i guess, that you need to increase the geometry tolerance to a finer level. The arc might not be finely resolved enough for your small elements. Have a look into the icem settings. Under model/units is a field for triangulation tolerance. Increase this value below your smallest mesh length, e.g. 1e-7. Then recalculate your premesh. With regards, Sebastian |
September 8, 2016, 07:31 |
Niklas
Rep Power: 10 |
Hey Sebastian,
thanks for your answer! So I tried to change the tolerances before I posted my question. When I did that, the position of the bad elements changed from the inner wall to the outer wall. I tried to mesh the geometry again. I noticed, when I created the 2D blocking, everything was just fine, but when I translated it to 3D, the Determinants dropped. |
September 8, 2016, 09:32 |
Sebastian Engel
Rep Power: 21 |
Hi Niklas,
have a look at this thread: http://www.cfd-online.com/Forums/ans...y-small-y.html Here it's suggested to activate project to bspline in the hexa mesh settings. This might solve your problem. I also suggest to reload your project when you have changed the settings. With regards, Sebastian |
September 8, 2016, 13:37 |
Niklas
Rep Power: 10 |
Hi Sebastian,
seems like this helped! Thank you so much! Best regards, Niklas |
determinant, icem, meshing |
[ICEM] Determinant 3x3x3 | Batis | ANSYS Meshing & Geometry | 3 | April 30, 2018 06:57 |
[ICEM] negative Determinant 3x3x3 after applying O-grid | ticofiz | ANSYS Meshing & Geometry | 1 | January 13, 2016 02:18 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Bad elements in the narrow gap | saisanthoshm88 | ANSYS Meshing & Geometry | 6 | January 25, 2011 13:22 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
