[DesignModeler] Interface in heat exchanger
Old   September 5, 2016, 10:38
Default Interface in heat exchanger
Aldanu is on a distinguished road
Good morning,
I have a problem when meshing a heat exchanger: since it is made of a tube in another tube, I should create an interface between them, but I have no idea how to do so. The best I could do is a couple of sketches, one for the Inner tube and one for the outer one, before creating two surfaces out of them and extruding them. Unfortunately this means I had to create two overlapping circumferences, perfectly identical, for the two surfaces. This gives problems because openfoam does not understand they are a single interface. Thank you in advance.
Aldanu is offline   Reply With Quote
Old   September 5, 2016, 19:55
Kapi is on a distinguished road
can i suggest you to go thru tutorials before you ask questions here?
Kapi is offline   Reply With Quote
Old   September 9, 2016, 01:54
Onur Özcan
oozcan is on a distinguished road
Originally Posted by Aldanu View Post
Good morning,
First,
You could do drawing in CAD software.(only fluid domains should be drawn)
Import to ANSYS-WORKBENCH Geometry named DesignModeler
All faces should be given named selection
Meshing properly to y+ ( y+=1 or y+>30)
Contact faces should be choosen in FLUENT mesh interfaces tab.
İt is not needed for perfect mesh between two contact surfaces/faces.
Shared topology is so critical in contact faces that you should select imprints
oozcan is offline   Reply With Quote
heat, interface
Ansys Fluent analysis of heat exchanger MStudent FLUENT 2 April 20, 2015 09:40
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Heat Flux Profile at Fluid-Porous Interface Hitch8 CFX 4 December 15, 2012 10:57
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
