[ANSYS Meshing] Solidworks imported into design modeler, Circular edges become polygon!!!
Old   September 1, 2016, 03:46
Default Solidworks imported into design modeler, Circular edges become polygon!!!
Ftab
ftab is on a distinguished road
Hi all,
I am trying to import a model from Solidworks into Workbench to mesh and run simulation. Although I have increased the resolution to Max in Solidworks and cirrcular planes are very accurate, the edges (circular edge of Cylindrical shape) is terribly polygonal. As I have interfaces there (two concentric cylinders) the simulation is giving me the error of intersection for interfaces. Edges look perfect in solidworks, but not in designmodeler.
How can I improve the resolution of edges, as manipulating the parameters of intersection and GGI could not fix it.
Thanks
ftab is offline   Reply With Quote
Old   September 4, 2016, 23:28
Kapi is on a distinguished road
which format are you importing the geometry in?
Kapi is offline   Reply With Quote
Old   September 5, 2016, 00:30
Ftab
Thanks for the reply Kapi. I have used Solidworks part file in workbench, and imported to design modelr.
By the way, I have also tested any other format (STEP, PARASOLID, ACIS, STL,...) separately in icemCFD, wherein the geometry has multiple holes on different places which makes it impossible to mesh. Those holes do not exist in Solid model, and only appear by importing into ICEM. That is why I insisted to use workbench meshing tool, although having quite some of experience in ICEM.
Old   September 5, 2016, 01:06
i prefer Parasolid format to import geometry in DM.
Suggest you to Name select the geometry in solidworks and then bring them in.
It is possible just the visual edges are not correct but infact they are correct for modelling. Do check that.
When going in mesh, try to give "sizing" function as required to those edges and you should be fine both visually and numerically.
Old   September 6, 2016, 12:17
Ftab
Hi Kapi,
I did as you suggested to name the different surfaces and parts in Solid. Still problem with edges.
It is not only visual, as when I mesh and run the simulation the interfaces do not intersect and the simulation crashes.
[IMG] https://drive.google.com/open?id=0Bw...DZ5WmtLb0lBSFk [/IMG]
Now when I try ICEM, not only the edges are screwed, there are holes no matter what format the model is:
[IMG] https://drive.google.com/open?id=0Bw...0ROeDgwdVE1a1k [/IMG]
So, I am still stuck!!
Old   September 6, 2016, 12:49
Ftab
And look how good it looks in solid!!
[IMG] https://drive.google.com/open?id=0Bw...kdZTVVKM2FKWk0 [/IMG]
Old   September 12, 2016, 00:20
Ftab
As an update and to thank Kapi:
I solved the problem by specifically giving sizing for the edges as Kapi kindly suggested above
design modeler, edges, interface problem, mesh 3d
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[DesignModeler] Rotating an imported part in Design Modeler mikko ANSYS Meshing & Geometry 2 November 30, 2015 01:23
[DesignModeler] How to write the script in the ansys design modeler? deddy1973 ANSYS Meshing & Geometry 3 October 4, 2013 06:08
design modeler zikozaki01 FLUENT 4 May 30, 2012 18:17
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
