[DesignModeler] Problem with parameters in DM |
August 31, 2016, 09:49 |
Björn
Rep Power: 16 |
Hi!
I am having a problem with the parameters in DM. This should be the a very trivial thing but it doesn't work (please see pictures) OK! when I set the diameter to 50 mm it works very nice but when I set the diameter to 20 mm DM has problems to build the geometry. I've tried almost everything - changing the parameters order, changing the references...Probably I'm doing a mistake somewhere...has anyone a hint? (V17.1) Thank you :-) |
August 31, 2016, 23:23 |
Rep Power: 14 |
have u clicked on it to see what error it is giving?
September 1, 2016, 04:27 |
Björn
Rep Power: 16 |
Sure, sorry :-)
September 4, 2016, 23:33 |
Rep Power: 14 |
two things:
either you have assigned dimention twice or more or the value you are giving (20) is too small for the dimension to make a close loop,hence not valid |
ansys 17.1, designmodeller, parameter, parmeters |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 05:28 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
Parameters for multigrid solver | HaZe | OpenFOAM Running, Solving & CFD | 3 | January 28, 2012 03:05 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 09:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
